[postgis-users] RE: Columnname GEOMETRY
Uwe Dalluege uwe.dalluege at rzcn.haw-hamburg.de
Sun May 29 22:32:05 PDT 2005
Hi Abe,
yes I am shure. I think the problem is the
function AddGeometryColumn ( ).
Please try it out and let me know if it works on you installation.
Best regards
Uwe
> Are you sure the column name is "GEOMETRY" (uppercase) and not
> "geometry" (lowercase)?  You have to take an extra step when creating
> a table to make anything uppercase - by default Postgres forces
> everything to lowercase.  It's a matter of:
> CREATE TABLE foo
>  "GEOMETRY" int4
> instead of
> CREATE TABLE foo
>  GEOMETRY int4
> -Abe
> On 5/27/05, Uwe Dalluege <uwe.dalluege at rzcn.haw-hamburg.de> wrote:
>> Hi,
>> I have a problem with the columnname "GEOMETRY".
>> When I do this:
>> create table point ( NR int4 );
>> select AddGeometryColumn ( 'dbgeo', 'point', 'GEOMETRY', 0, 'POINT', 3 );
>> insert into point ( nr, GEOMETRY ) values ( 100, GeometryFromText (
>> 'POINT
>> ( 100.0 200.0 10.3 )', 0 ) );
>> select * from point;
>> I receive the errormessage:
>> ERROR:  column "geometry" of relation "point" does not exist
>> But this works:
>> select AddGeometryColumn ( 'dbgeo', 'point', 'geometry', 0, 'POINT', 3 );
>> insert into point ( nr, geometry ) values ( 100, GeometryFromText (
>> 'POINT
>> Is there a different between the columnname "GEOMETRY" and "geometry"?
>> Uwe
Mit freundlichen Gruessen
Uwe Dalluege
Hochschule fuer Angewandte Wissenschaften Hamburg
- University of Applied Sciences -
Fachbereich Geomatik
Rechenzentrum
Dipl.-Ing. Uwe Dalluege   :-)
Hebebrandstr. 1
22297 Hamburg
Tel.: +49 40 42875 - 5335 oder 5353 oder 5313
Fax:  +49 40 42875 - 5409
E-Mail: mailto:uwe.dalluege at rzcn.haw-hamburg.de
Url: http://www.haw-hamburg.de/geomatik/
