[postgis-users] TopologyException with geomunion
strk at refractions.net strk at refractions.net
Thu Nov 3 01:48:24 PST 2005
Can you provide the HEXWKB (canonical output)
of the geometries triggering the error
if this happens with GEOS-2.1.4 ?
--strk;
On Wed, Nov 02, 2005 at 03:32:32PM +0000, David Orme wrote:
> Hi all,
> I've run into an exception when trying to union two multipolygons.
> The features are both simple and valid:
> range_maps=# select isvalid(geom), issimple(geom) from viverrid_psar
> where node_number in (-3,-21);
> isvalid | issimple
> t       | t
> t       | t
> (2 rows)
> but when I try and union these I get the following:
> range_maps=# insert into viverrid_psar (taxon_name, node_number,
> subclades, branch_length,  n_tips, n_subclades, node_height,
> richness, geom)values ('',-2,'{-3,-21}',9.9,31,2,18.1,31,(select
> geomunion(geom) from viverrid_PSAR where node_number in (-3,-21)));
> NOTICE:  TopologyException: Directed Edge visited twice during ring-
> building at  (1.13203e+07,402571)
> ERROR:  GEOS union() threw an error!
> I don't think I'm doing something dumb, but I thought I'd check
> before I start posting bug reports..
> Cheers,
> David
> postgis-users mailing list
