[postgis-users] TopologyException with geomunion
David Orme d.orme at imperial.ac.uk
Thu Nov 3 02:26:01 PST 2005
Sorry I forgot to put on the version data:
range_maps=# select postgis_full_version();
POSTGIS="1.0.4" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.0" RELPROC="0.3.0"
(1 row)
It is all built on a Apple G5 running Tiger.
The multipolygons are very large - the two  as HEXWKB are nearly 12
MB - I'm going to be very unpopular if I post that! What's the best
way of getting them to you?
Cheers,
David
On 3 Nov 2005, at 09:48, strk at refractions.net wrote:
> Can you provide the HEXWKB (canonical output)
> of the geometries triggering the error
> if this happens with GEOS-2.1.4 ?
> --strk;
> On Wed, Nov 02, 2005 at 03:32:32PM +0000, David Orme wrote:
>> Hi all,
>> I've run into an exception when trying to union two multipolygons.
>> The features are both simple and valid:
>> range_maps=# select isvalid(geom), issimple(geom) from viverrid_psar
>> where node_number in (-3,-21);
>> isvalid | issimple
>> t       | t
>> t       | t
>> (2 rows)
>> but when I try and union these I get the following:
>> range_maps=# insert into viverrid_psar (taxon_name, node_number,
>> subclades, branch_length,  n_tips, n_subclades, node_height,
>> richness, geom)values ('',-2,'{-3,-21}',9.9,31,2,18.1,31,(select
>> geomunion(geom) from viverrid_PSAR where node_number in (-3,-21)));
>> NOTICE:  TopologyException: Directed Edge visited twice during ring-
>> building at  (1.13203e+07,402571)
>> ERROR:  GEOS union() threw an error!
>> I don't think I'm doing something dumb, but I thought I'd check
>> before I start posting bug reports..
>> Cheers,
>> David
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
