[postgis-users] Re: Error in SPATIAL_REF_SYS table
Markus Schaber schabi at logix-tt.com
Wed Nov 9 05:25:50 PST 2005
Hi, Barend,
Barend Köbben wrote:
> I tried it and although it generaly works and is indeed better then
> the fixed table in some aspects, it does not solve my problem as I
> found out the EPSG database actually holds the wrong projection for
> the Rijksdriehoeksstelsel (Dutch National Grid)!
Then fix your local spatial_ref_sys so you can continue your work, and
tell the EPSG http://www.epsg.org/ about the problem so they can fix the
database, which will automagically fix all the projects that get their
data from the EPSG database (including postfix) in the long term.
Thanks,
Markus
