[postgis-users] Area and scale completely wrong
strk at refractions.net
Mon Nov 14 01:13:10 PST 2005
Does the area computation give acceptable value for the geometry's
envelope ? [ select area(envelope(the_geom)) ] ?
Is the geometry valid ? [ select isvalid(the_geom) ] ?
--strk;
On Mon, Nov 14, 2005 at 07:50:10PM +1100, Johan Wehtje wrote:
> I am using Postgis 1.0.4 on Win XP with Postgresql 8.1.
> I had some Shape files that have Land Parcels , they use GDA94 Zone 56 (
> srid 28356) , and I used shp2pgsql to load them into my DB.
> But when I an area calculation I get results that are completely wrong , and
> when i add a Postgis layer using QGIS the scale would have me beleive that
> the entire shire (which about 80 km accross) is about 2 cm.
> I have tried this about twenty times, on 2 different machines - and the
> results are the same. i have verified the original shape files in Arcview,
> and when they are laoded the scale and area are all what they should be.
> What am I doing wrong?
> Johan Wehtje
> postgis-users mailing list
/"\ ASCII Ribbon Campaign
\ / Respect for open standards
X No HTML/RTF in email
/ \ No M$ Word docs in email
