[postgis-users] Area and scale completely wrong
Johan Wehtje genwolf at gmail.com
Mon Nov 14 01:25:54 PST 2005
isvalid returns true, envelope gives results that make no sense outside of
the world of Lilliput.
I had some of the same maps but with MGA 84 zone 56 datum, and they have
loaded no problem, I therefore think that the definition for the GDA94
spatial refernces must be out of whack, because the shape files have no
problem when loaded in arc view in either GDA 94 or MGA 84.
The GDA 94 shapes have attached xml files, and the pojection string in these
does look the same as the proj4 text in the Spatial Refsys table, so I don't
know what is going wrong.
Cheers
(and thanks your help)
Johan Wehtje
On 11/14/05, strk at refractions.net <strk at refractions.net> wrote:
> Does the area computation give acceptable value for the geometry's
> envelope ? [ select area(envelope(the_geom)) ] ?
> Is the geometry valid ? [ select isvalid(the_geom) ] ?
> --strk;
> On Mon, Nov 14, 2005 at 07:50:10PM +1100, Johan Wehtje wrote:
> > I am using Postgis 1.0.4 on Win XP with Postgresql 8.1.
> > I had some Shape files that have Land Parcels , they use GDA94 Zone 56 (
> > srid 28356) , and I used shp2pgsql to load them into my DB.
> > But when I an area calculation I get results that are completely wrong ,
> and
> > when i add a Postgis layer using QGIS the scale would have me beleive
> that
> > the entire shire (which about 80 km accross) is about 2 cm.
> > I have tried this about twenty times, on 2 different machines - and the
> > results are the same. i have verified the original shape files in
> Arcview,
> > and when they are laoded the scale and area are all what they should be.
> > What am I doing wrong?
> > Johan Wehtje
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> /"\ ASCII Ribbon Campaign
> \ / Respect for open standards
> X No HTML/RTF in email
> / \ No M$ Word docs in email
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051114/6e386bba/attachment.html>
