[postgis-users] Input on upgrade to GIS database
Sears, Jeremy
Jeremy.Sears at CCRS.NRCan.gc.ca
Thu Nov 17 08:37:58 PST 2005
Onyx,
I have recently preformed a simmilar task. In the name of experimentation I
had tried a coupla methods to move data from an older PostgreSQL(8.0.2) +
PostGIS install to a new one (postgresql 8.1 and postgis 1.0.4). The older
database dumped data into a sql loader file. This was then loaded into the
new database via 'psql -f datafile.sql'. This method seems to have worked
although I did notice a couple of errors fly by as the data loaded. . . Note
that the new database is still in the testing phase and errors could exist
that I havent noticed yet.. however so far so good.
Jeremy
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Onyx
Sent: November 17, 2005 11:01 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Input on upgrade to GIS database
PostGIS Friends,
I need some help/input on the proper approach to upgrading on GIS-driven
database backend, and I am hoping that some of you have been in similar
situations. We run a PostgreSQL database with Proj, Geos, and (of course)
PostGIS libraries. I want to upgrade the following:
- PostgreSQL 7.4.6 --> 8.1.0
- Geos 2.1.0 --> 2.1.4
- PostGIS 0.9.0 --> 1.0.4
What is the proper approach to get this done successfully, keeping our
existing data intact? I know that it is not as simple as 1) dumping the
schema & data from the database to a file, 2) moving/deleting PostgreSQL
7.4.6 (and old libraries), 3) installing PostgreSQL 8.1.0 (and the new
libraries), and 4) feeding the schema & data back in, although I wish it
were that easy. I have read the section of the PostGIS manual on upgrading,
but I am worried that there are some other aspects I need to know since I
have other variables I am upgrading as well (PostgreSQL & Geos). Has anyone
been in my boat before?
Any help would be greatly appreciated. Thanks!
- Onyx
Onyx Mueller
Software Engineer
i-cubed : information integration & imaging LLC
201 Linden Street : Third Floor
Fort Collins, CO 80524
970-482-4400 voice
970-482-4499 fax
<http://www.i3.com> http://www.i3.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051117/a08bc589/attachment.html>
