[postgis-users] installing postgis in Ubuntu 5.10(Breezy)
John Taber
jtaber at johntaber.net
Thu Nov 17 09:22:51 PST 2005
alex bodnaru wrote:
> the *c2 dependency is been automatically added on relevant platforms only.
> if you make postgis from sources in an 4.01 environment, the dependency
> will be libgeos2, instead of libgeos2c2.
> i'm sending the sources, so that you will try and be convinced.
Sorry, I am getting lost on this. I'll try later today to review
everything.
> alex
> John Taber wrote:
>>alex bodnaru wrote:
>>>if you have postgresql-common installed, i might send you the packages
>>>later.
>>I appreciate your help, but I think you are working in unstable with
>>libstdc++ 4.02 and I'm in Breezy with libstdc++4.01. If Blair can fix
>>his pkg then that gives Breezy users both postgresql 8.1 & postgis.
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
