[postgis-users] Remoce french accents
strk at refractions.net strk at refractions.net
Fri Nov 18 02:52:16 PST 2005
If you rebuild the loader with USE_ICONV set to 1 it will give
you a -W switch to support multiple encodings.
--strk;
On Fri, Nov 18, 2005 at 11:33:25AM +0100, laurent.cuzon at ingencys.net wrote:
> Hi all,
> I've got a problem when I try to import files containing french accents in
> my PostGis database.
> Is there a way to remove accents when I convert my shapefile te sql file,
> or when I import my sql file in the database?
> Thanks in advance.
> Laurent Cuzon
> postgis-users mailing list
