[postgis-users] Breezy pkgs - no data when selecting
John Taber
jtaber at johntaber.net
Fri Nov 18 05:23:24 PST 2005
I installed the new Breezy packages from Blair - it went very well
(thank you Blair). After they were installed and I set up a user, I
tested with the example in the documentation FAQ section. I had no
errors until I went to select something - it returned nothing. No
errors but no data. I have double checked my insert statement several
times. Is there a better way for me to test? I need to check:
1) if pkgs are working right
2) if example is right
3) most likely, what am I doing wrong or failed to do.
Any ideas - thks.
