[postgis-users] Re: Breezy pkgs - no data when selecting
John Taber
jtaber at johntaber.net
Fri Nov 18 10:57:53 PST 2005
okay, now when I type psql mydb, I am getting version 7.4.8 and when I
try to AddGeometryColumn I'm getting an error - how do I get my newly
installed postgres/postgis version 8.1 if they are both coinciding on
the system - do I specify something when I create a database? Do I need
to change some environmental variable that the debs did not change ?
thks for any help
John Taber wrote:
> I installed the new Breezy packages from Blair - it went very well
> (thank you Blair). After they were installed and I set up a user, I
> tested with the example in the documentation FAQ section. I had no
> errors until I went to select something - it returned nothing. No
> errors but no data. I have double checked my insert statement several
> times. Is there a better way for me to test? I need to check:
> 1) if pkgs are working right
> 2) if example is right
> 3) most likely, what am I doing wrong or failed to do.
> Any ideas - thks.
