Trouble with AsText(ExteriorRing()) Re: [postgis-users] IsSimple terminating connection
Diez B. Roggisch
deets at web.de
Sat Nov 26 04:19:40 PST 2005
strk at refractions.net wrote:
> So, you get a segfault with:
> - GEOS-2.1.4
> - postgis-1.0.5
> - postgres-8.0.4
> What architecture ?
> Do regression tests give you a segfault as well ?
Ok, I ran them - with this results:
deets at absinth:~/software/deb/postgresql-8.1-8.1.0/build-tree/postgresql-8.1.0/contrib/postgis-1.0.5/regress$
make
Running Normal Regression Test.
Output file is: '/tmp/regress_out_10706'
expected:'<' obtained:'>'
Running Index Regression.
Output file is: '/tmp/regress_index_out_10721'
Index Creation will take some time...
Running LWGEOM Regression Test...
Output file is: '/tmp/regress_lwgeom_out_10734'
Building a database for testing (postgis_reg).
Building postgis support in it.
there shouldnt be any real output produced after this line.
Running OGC Regression Test...
Output file is: '/tmp/regress_ogc_out_10748'
19a20
> NOTICE: Self-intersection
Not sure what to make out of these.
Regards,
Diez
