[postgis-users] Making shp2pgsql using iconv in /usr/local?
strk at refractions.net
Tue Nov 29 00:53:45 PST 2005
You only need to rebuild shp2pgsql, which is the only
place where iconv is used.
Currently there's no support for iconv in a separate library:
it is assumed iconv funx are provided by C lib.
Anyway you can set LDFLAGS in the environment:
$ cd PGISSRC/loader
$ make clean
$ LDFLAGS="-L/usr/local/lib -liconv" \
> CFLAGS="-I/usr/local/include" make shp2pgsql
You might need -rpath for forcing runtime binding to
a specific version, check ld(8)
--strk;
On Mon, Nov 28, 2005 at 05:14:10PM -0700, Larry Shaffer wrote:
> Hi,
> Just wondering, is there is a way to set the prefix path for the
> requested iconv library when doing a make of the shp2pgsql utility? I
> would like to have the utility support utf-8.
> I have a new version of iconv installed in /usr/local and don't want to
> use the /usr copy of iconv, because anything below local is the 'managed'
> part of my managed Debian Linux server from a provider - and I don't want
> to mess with it. I have root access, but have agreed to install only at
> the /usr/local level. I have successfully installed PostGIS without the
> iconv support.
> I'm not a Debian guru, but I'm sure there is a way to tell the compiler
> to link to the /usr/local copy of iconv somewhere in the make file, or
> when running make. Any ideas?
> Also, if I can successfully use the /usr/local iconv install to make the
> shp2pgsql utility, will I have to re-compile PostGIS as well? Or, can I
> just re-make the utility after PostGIS has been installed?
> Thanx
> Larry
> postgis-users mailing list
/"\ ASCII Ribbon Campaign
\ / Respect for open standards
X No HTML/RTF in email
/ \ No M$ Word docs in email
