[postgis-users] shp2pgsql -> pgsql2shp problem
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Oct 1 21:30:58 PDT 2005
Hi all,
I just tried to use shp2pgsql and pgsql2shp to rename some columns in
Canadian hydrology shpfiles. I seems they named the original columns
"xxCART_" and "xxCART_ID" where xx is the province abbreviation. Each
province's shapefile has different column names. So you can't build a
mapserver tileindex. So I wrote the following bash script to use postgis
to rename the columns:
mkdir ../p-new
for x in ab bc mb nb nf ns nt nu on pe qc sk yt ; do
y=${x}drcarto_p
echo $y
shp2pgsql -c -W LATIN1 $y $y | psql -U pgsql -h localhost temp > /dev/null
echo "alter table $y rename ${x}cart_ to cart_;" | psql -U pgsql -h
localhost temp
echo "alter table $y rename ${x}cart_id to cart_id;" | psql -U pgsql -h
localhost temp
(cd ../p-new ; pgsql2shp -f $y -u pgsql -h localhost -g the_geom temp $y )
echo "drop table $y;" | psql -U pgsql -h localhost temp
done
This works great EXCEPT the output column widths are not the same as the
input column widths. See below! Is there a way to force this to be the
same? Why are they not the same as their sql definitions?
-Steve
woodbri at linus:/u/data/canada/hydro/p-new$ dbfdump -info abdrcarto_p
Filename: abdrcarto_p.dbf
Version: 0x03 (ver. 3)
Num of records: 3165
Header length: 353
Record length: 180
Last change: 1995/7/26
Num fields: 10
Field info:
Num Name Type Len Decimal
1. AREA N 32 10
2. PERIMETER N 32 10
3. CART_ N 16 0
4. CART_ID N 16 0
5. F_CODE C 5 0
6. HYC N 16 0
7. CGNDB_EN C 5 0
8. CGNDB_FR C 5 0
9. NAME_EN C 26 0
10. NOM_FR C 26 0
woodbri at linus:/u/data/canada/hydro/p-new$ dbfdump -info ../p/abdrcarto_p
Filename: ../p/abdrcarto_p.dbf
Header length: 353
Record length: 261
Last change: 2003/6/20
Num fields: 10
Field info:
1. AREA N 18 5
2. PERIMETER N 18 5
3. ABCART_ N 11 0
4. ABCART_ID N 11 0
5. F_CODE C 5 0
6. HYC N 11 0
7. CGNDB_EN C 5 0
8. CGNDB_FR C 5 0
9. NAME_EN C 88 0
10. NOM_FR C 88 0
