[postgis-users] shp2pgsql -> pgsql2shp problem
strk at refractions.net
Mon Oct 3 01:07:18 PDT 2005
Stephen, no way to specify dbf attribute sizes currently.
Integer columns are output with a length of 16.
Floating values with a length of 32.
Why do you find they are not the same as their sql definitions ?
--strk;
On Sun, Oct 02, 2005 at 12:30:58AM -0400, Stephen Woodbridge wrote:
> Hi all,
> I just tried to use shp2pgsql and pgsql2shp to rename some columns in
> Canadian hydrology shpfiles. I seems they named the original columns
> "xxCART_" and "xxCART_ID" where xx is the province abbreviation. Each
> province's shapefile has different column names. So you can't build a
> mapserver tileindex. So I wrote the following bash script to use postgis
> to rename the columns:
> mkdir ../p-new
> for x in ab bc mb nb nf ns nt nu on pe qc sk yt ; do
> y=${x}drcarto_p
> echo $y
> shp2pgsql -c -W LATIN1 $y $y | psql -U pgsql -h localhost temp > /dev/null
> echo "alter table $y rename ${x}cart_ to cart_;" | psql -U pgsql -h
> localhost temp
> echo "alter table $y rename ${x}cart_id to cart_id;" | psql -U pgsql -h
> localhost temp
> (cd ../p-new ; pgsql2shp -f $y -u pgsql -h localhost -g the_geom temp $y )
> echo "drop table $y;" | psql -U pgsql -h localhost temp
> done
> This works great EXCEPT the output column widths are not the same as the
> input column widths. See below! Is there a way to force this to be the
> same? Why are they not the same as their sql definitions?
> -Steve
> woodbri at linus:/u/data/canada/hydro/p-new$ dbfdump -info abdrcarto_p
> Filename: abdrcarto_p.dbf
> Version: 0x03 (ver. 3)
> Num of records: 3165
> Header length: 353
> Record length: 180
> Last change: 1995/7/26
> Num fields: 10
> Field info:
> Num Name Type Len Decimal
> 1. AREA N 32 10
> 2. PERIMETER N 32 10
> 3. CART_ N 16 0
> 4. CART_ID N 16 0
> 5. F_CODE C 5 0
> 6. HYC N 16 0
> 7. CGNDB_EN C 5 0
> 8. CGNDB_FR C 5 0
> 9. NAME_EN C 26 0
> 10. NOM_FR C 26 0
> woodbri at linus:/u/data/canada/hydro/p-new$ dbfdump -info ../p/abdrcarto_p
> Filename: ../p/abdrcarto_p.dbf
> Header length: 353
> Record length: 261
> Last change: 2003/6/20
> Num fields: 10
> Field info:
> 1. AREA N 18 5
> 2. PERIMETER N 18 5
> 3. ABCART_ N 11 0
> 4. ABCART_ID N 11 0
> 5. F_CODE C 5 0
> 6. HYC N 11 0
> 7. CGNDB_EN C 5 0
> 8. CGNDB_FR C 5 0
> 9. NAME_EN C 88 0
> 10. NOM_FR C 88 0
> postgis-users mailing list
