[postgis-users] ArcGIS/ArcView client to the PostGIS?
Abe Gillespie
abe.gillespie at gmail.com
Mon Oct 3 15:18:12 PDT 2005
I guess this is my cue.
As far as I know there's no viable solution yet. There's this:
http://sourceforge.net/projects/pgarc/
but that project seems to have died a while ago.
The other option is a project I'm heading up. Check it out here:
http://avoir.uwc.ac.za/projects/ziggis/
zigGIS is just getting started but already has full read-only support.
Unfortunately it isn't easy getting it compiled and configured quite
yet. If you're a developer and can volunteer some time we could
really use your help.
Thanks.
-Abe
On 10/3/05, Carlos Gonçalves <carlosfgo at gmail.com> wrote:
> Hi All.
> I would like to know if exists some way to connect a ArcGIS/ArcView client
> to the PostGIS?
> Carlos F. Gonçalves
> "E não há salvação em nenhum outro; porque abaixo do céu não existe nenhum
> outro nome, dado entre os homens, pelo qual importa que sejamos salvos"(Atos
> 4:12)
> JESUS CRISTO
> Center for Metropolitan Studies (Centro de Estudos da Metropole).
> Know the Metropolitan Region of São Paulo (Conheça a Região Metropolitana
> de São Paulo).
> http://www.mapas.centrodametropole.org.br/servidormapas/html/index.html
> For the good operation of this application, it is necessary to have
> installed in yours computer the plug-in Adobe SVG Viewer (Para o bom
> funcionamento deste aplicativo, é necessário ter instalado em seu
> computador o plug-in Adobe SVG Viewer).
> Português:
> http://www.adobe.com/svg/viewer/install/main.html
> postgis-users mailing list
