[postgis-users] ArcGIS/ArcView client to the PostGIS?
Chris Matheson
chris at centralfrontenac.com
Tue Oct 4 05:52:49 PDT 2005
Carlos:
UMN Mapserver (http://mapserver.gis.umn.edu) can use PostGIS
data-sources. Possibly you could use the UMN Mapserver ArcIMS emulator
(http://mapserver.refractions.net/) and connect to that in ArcCatalog.
This might give you view access.
Chris M.
Carlos Gonçalves wrote:
> Hi All.
> I would like to know if exists some way to connect a ArcGIS/ArcView
> Carlos F. Gonçalves
> "E não há salvação em nenhum outro; porque abaixo do céu não existe
> nenhum outro nome, dado entre os homens, pelo qual importa que sejamos
> salvos"(Atos 4:12)
> JESUS CRISTO
> Center for Metropolitan Studies (Centro de Estudos da Metropole).
> Know the Metropolitan Region of São Paulo (Conheça a Região Metropolitana
> de São Paulo).
> http://www.mapas.centrodametropole.org.br/servidormapas/html/index.html
> For the good operation of this application, it is necessary to have
> installed in yours computer the plug-in Adobe SVG Viewer (Para o bom
> funcionamento deste aplicativo, é necessário ter instalado em seu
> computador o plug-in Adobe SVG Viewer).
> Português:
> http://www.adobe.com/svg/viewer/install/main.html
> <http://www.adobe.com/svg/viewer/install/main.html>
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Chris Matheson
Information Technologist / Project Coordinator
Central Frontenac Township - http://www.centralfrontenac.com
phone: 613-279-2935 ext. 245
fax: 613-279-2422
email: chris at centralfrontenac.com
