[postgis-users] ArcGIS/ArcView client to the PostGIS?
Paul Ramsey
pramsey at refractions.net
Tue Oct 4 13:14:26 PDT 2005
If you like Java, and you want PostGIS connectivity, try uDig. But
you specified ArcView/ArcGIS...?
P.
On Oct 4, 2005, at 1:00 PM, Carlos Gonçalves wrote:
> Hi Abe and Chris
> I liked it very its project, but my experience is in Java.
> http://avoir.uwc.ac.za/projects/ziggis/
> I do not know how much of the structure of Java he is seemed C#.
> I know that for proper characteristics of its team it has more
> familiarity with C#.
> It has some possibility to develop a version for Java?
> One another question.
> Chris M. sent one another possibility that is:
> UMN Mapserver (http://mapserver.gis.umn.edu) can use PostGIS
> data-sources.
> Which is the difference between the two?
> Which of systems one client of the ArcGIS/ArcView type can read/
> write in the PostGIS?
> It would like to thank to the you Abe and Chris for explanation
> these questions.
> Thank you.
> Carlos F. Gonçalves
> "E não há salvação em nenhum outro; porque abaixo do céu não existe
> nenhum outro nome, dado entre os homens, pelo qual importa que
> sejamos salvos"(Atos 4:12)
> JESUS CRISTO
> Center for Metropolitan Studies (Centro de Estudos da Metropole).
> Know the Metropolitan Region of São Paulo (Conheça a Região
> Metropolitana
> de São Paulo).
> http://www.mapas.centrodametropole.org.br/servidormapas/html/
> index.html
> For the good operation of this application, it is necessary to have
> installed in yours computer the plug-in Adobe SVG Viewer (Para o bom
> funcionamento deste aplicativo, é necessário ter instalado em seu
> computador o plug-in Adobe SVG Viewer).
> Português:
> http://www.adobe.com/svg/viewer/install/main.html
> postgis-users mailing list
