[postgis-users] ArcGIS/ArcView client to the PostGIS?
Carlos Gonçalves carlosfgo at gmail.com
Tue Oct 4 13:00:24 PDT 2005
Hi Abe and Chris
I liked it very its project, but my experience is in Java.
http://avoir.uwc.ac.za/projects/ziggis/
I do not know how much of the structure of Java he is seemed C#.
I know that for proper characteristics of its team it has more familiarity
with C#.
It has some possibility to develop a version for Java?
One another question.
Chris M. sent one another possibility that is:
UMN Mapserver (http://mapserver.gis.umn.edu) can use PostGIS
data-sources.
Which is the difference between the two?
Which of systems one client of the ArcGIS/ArcView type can read/write in the
PostGIS?
It would like to thank to the you Abe and Chris for explanation these
questions.
Thank you.
Carlos F. Gonçalves
"E não há salvação em nenhum outro; porque abaixo do céu não existe nenhum
outro nome, dado entre os homens, pelo qual importa que sejamos salvos"(Atos
4:12)
JESUS CRISTO
Center for Metropolitan Studies (Centro de Estudos da Metropole).
Know the Metropolitan Region of São Paulo (Conheça a Região Metropolitana
de São Paulo).
http://www.mapas.centrodametropole.org.br/servidormapas/html/index.html
For the good operation of this application, it is necessary to have
installed in yours computer the plug-in Adobe SVG Viewer (Para o bom
funcionamento deste aplicativo, é necessário ter instalado em seu
computador o plug-in Adobe SVG Viewer).
Português:
http://www.adobe.com/svg/viewer/install/main.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051004/e85bd846/attachment.html>
