[postgis-users] ArcGIS/ArcView client to the PostGIS?
Marco Vieira marco_vieira at uk2.net
Tue Oct 4 13:46:51 PDT 2005
Chris:
  I tried the ESRI Data Interoperability with no sucess. I downloaded from
ESRI website a 60 days trial version and tested the connection with the
regional office ESRI guys on my PostGIS 1.0.0. I that time Abe suppose
that the FME conector only run on versions 0.9x.
(http://postgis.refractions.net/pipermail/postgis-users/2005-July/008834.html).
I guess  he are right. The Brazillian ESRI regional Office was opened a
trouble ticket on ESRI headquarter. Maybe something change on ArcGIS +
DI 9.1.
Marco Vieira.
Fone:    + 55 21 9499-6800
> Out of curiousity, has anyone out there tried the ESRI Data
> Interoperability Extension with PostGIS?
> Chris M.
> Carlos Gonçalves wrote:
>> Hi All.
>> I would like to know if exists some way to connect a ArcGIS/ArcView
>> Carlos F. Gonçalves
>> "E não há salvação em nenhum outro; porque abaixo do céu não existe
>> nenhum outro nome, dado entre os homens, pelo qual importa que sejamos
>> salvos"(Atos 4:12)
>> JESUS CRISTO
>> Center for Metropolitan Studies (Centro de Estudos da Metropole).
>> Know the Metropolitan Region of São Paulo (Conheça a Região
>> Metropolitana
>> de São Paulo).
>> http://www.mapas.centrodametropole.org.br/servidormapas/html/index.html
>> For the good operation of this application, it is necessary to have
>> installed in yours computer the plug-in Adobe SVG Viewer (Para o bom
>> funcionamento deste aplicativo, é necessário ter instalado em seu
>> computador o plug-in Adobe SVG Viewer).
>> Português:
>> http://www.adobe.com/svg/viewer/install/main.html
>> <http://www.adobe.com/svg/viewer/install/main.html>
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> Chris Matheson
> Information Technologist / Project Coordinator
> Central Frontenac Township - http://www.centralfrontenac.com
> phone: 613-279-2935 ext. 245
> fax: 613-279-2422
> email: chris at centralfrontenac.com
