[postgis-users] ArcGIS/ArcView client to the PostGIS?
Guy Carpenter
guyc at atgis.com.au
Tue Oct 4 19:38:43 PDT 2005
I tried the ESRI Data Interoperability Extensions
with ArcGIS 9.0 last year.
It mostly worked, but it had enough problems
that I couldn't use it in a production
environment.
I also sent a few bugs to Safe
Software, and my impression was that they
were making good progress fixing them. However
the discussion here recently
indicated the latest releases are still buggy.
It would be great to see some developer momentum
behind the ziggis project. I'll step up to help
when I can, but that will not be for a while yet.
Cheers,
Guy Carpenter
Atherton Tablelands GIS
Queensland, Australia
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Marco
Vieira
Sent: Wednesday, 5 October 2005 6:47 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ArcGIS/ArcView client to the PostGIS?
Chris:
I tried the ESRI Data Interoperability with no sucess. I downloaded from
ESRI website a 60 days trial version and tested the connection with the
regional office ESRI guys on my PostGIS 1.0.0. I that time Abe suppose that
the FME conector only run on versions 0.9x.
(http://postgis.refractions.net/pipermail/postgis-users/2005-July/008834.htm
l).
I guess he are right. The Brazillian ESRI regional Office was opened a
trouble ticket on ESRI headquarter. Maybe something change on ArcGIS + DI
9.1.
Marco Vieira.
Fone: + 55 21 9499-6800
marco_vieira at uk2.net
> Out of curiousity, has anyone out there tried the ESRI Data
> Interoperability Extension with PostGIS?
> Chris M.
> Carlos Gonçalves wrote:
>> Hi All.
>> I would like to know if exists some way to connect a ArcGIS/ArcView
>> Carlos F. Gonçalves
>> "E não há salvação em nenhum outro; porque abaixo do céu não existe
>> nenhum outro nome, dado entre os homens, pelo qual importa que
>> sejamos salvos"(Atos 4:12) JESUS CRISTO
>> Center for Metropolitan Studies (Centro de Estudos da Metropole).
>> Know the Metropolitan Region of São Paulo (Conheça a Região
>> Metropolitana de São Paulo).
>> http://www.mapas.centrodametropole.org.br/servidormapas/html/index.ht
>> ml For the good operation of this application, it is necessary to
>> have installed in yours computer the plug-in Adobe SVG Viewer (Para o
>> bom funcionamento deste aplicativo, é necessário ter instalado em seu
>> computador o plug-in Adobe SVG Viewer).
>> Português:
>> http://www.adobe.com/svg/viewer/install/main.html
>> <http://www.adobe.com/svg/viewer/install/main.html>
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> Chris Matheson
> Information Technologist / Project Coordinator Central Frontenac
> Township - http://www.centralfrontenac.com
> phone: 613-279-2935 ext. 245
> fax: 613-279-2422
> email: chris at centralfrontenac.com
