[postgis-users] ArcGIS/ArcView client to the PostGIS?
Isidoro Arroyo Barrantes
isidoro at consorciomerida.org
Wed Oct 5 06:01:28 PDT 2005
Chris Matheson escribió:
> Out of curiousity, has anyone out there tried the ESRI Data
> Interoperability Extension with PostGIS?
> Chris M.
I use Data interoperability extension (DIE) with ArcGIS 9 to access
PostGIS 0.9.1 and PostgreSQL 7.4.5 on Debian 3.1.
My tests works fine, but DIE can only read from PostGIS database
(although it can import/export tables).
The best is that DIE can use views. We makes views with sophisticated
queries at postGIS side and we use DIE + ArcMAP to print the resulting maps.
zigGIS project sounds really well.
Isidoro.
