[postgis-users] Problem with functions contains
Miguel de la Fuente
mjdelafuente at gmail.com
Tue Oct 4 14:09:57 PDT 2005
strk: I' have the following problem, when I use the function contains it
returns true when the polygons is not totally contains.
I have applied snaptogrid in my geometry column.
I did the following :
update table1 set new_geom=snaptogrid(the_geom,1e-2)
update table2 set new_geom=snaptogrid(the_geom,1e-2))
When I use the function contains()
select
b.*
from table2 b, table1 a
where contains (b.new_geom,a.new_geom)
it returns true,but I see visually that b not contains completely a.
I don't understand why??
I attach the data and a image showing the problem.
Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051004/0ef917d8/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051004/0ef917d8/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051004/0ef917d8/attachment-0001.obj>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051004/0ef917d8/attachment.jpe>
