[postgis-users] ArcGIS/ArcView client to the PostGIS?
Paul Ramsey
pramsey at refractions.net
Tue Oct 4 14:34:11 PDT 2005
Carlos,
I am not entirely following due to language issues but:
- uDig is internationaliz*able* but currently has just ES, EN, DE, FR
translations.
- CadCorp SIS has as much functionality as ArcGIS at approx 1/10 the
price.
- I know of no guaranteed way of doing ArcGIS/ArcView connectivity to
PostGIS.
Paul
On 4-Oct-05, at 1:37 PM, Carlos Gonçalves wrote:
> Hi Paul.
> >>>If you like Java, and you want PostGIS connectivity, try uDig. But
> >>>you specified ArcView/ArcGIS...?
> >>>P.
> Yes, I like Java.
> A question on uDig. It has an internationalized version? Portuguese?
> It has possibility to use plug-ins developed for the JUMP? Raster?
> But my problem is that I have to know if exists a solution that
> makes possible clients ArcGIS/ArcView if to connect to the PostGIS
> to read and writer?
> The problem :
> It has a project where the users use ArcGIS/ArcView licenses mono-
> users, the demand of the project is to pass all them to layer and
> data it PostGIS and to make with that the customers pass to have
> access to the PostGIS.
> For this necessary of a connection between clients ArcGIS/ArcView
> and the PostGIS that reads and writes in the base.
> Thank you
> Carlos F. Gonçalves
> "E não há salvação em nenhum outro; porque abaixo do céu não existe
> nenhum outro nome, dado entre os homens, pelo qual importa que
> sejamos salvos"(Atos 4:12)
> JESUS CRISTO
> Center for Metropolitan Studies (Centro de Estudos da Metropole).
> Know the Metropolitan Region of São Paulo (Conheça a Região
> Metropolitana
> de São Paulo).
> http://www.mapas.centrodametropole.org.br/servidormapas/html/
> index.html
> For the good operation of this application, it is necessary to have
> installed in yours computer the plug-in Adobe SVG Viewer (Para o bom
> funcionamento deste aplicativo, é necessário ter instalado em seu
> computador o plug-in Adobe SVG Viewer).
> Português:
> http://www.adobe.com/svg/viewer/install/main.html
> postgis-users mailing list
