[postgis-users] ArcGIS/ArcView client to the PostGIS?
Roy Irwan mroy at centrin.net.id
Wed Oct 5 19:28:06 PDT 2005
I believe, what you mean by the 'dependency dlls' is the .NET
assemblies. You can install ArcObjects .NET assemblies which is included
in ArcGIS Desktop package. I use ArcGIS 9.0, and the assemblies in the
1st CD.
Since zigGIS designed for ArcObjects 8.x, and from version 9.0, ESRI was
re-organizing the ArcObjects, so you have to change all ArcObjects 8.x
references to the new ArcObjects 9.x assemblies.
I also recommend you to install ArcObjects Developer Kit (CD2) which is
include the developer guide to guide you to make all those changes.
Rgds,
Roy Irwan
Obe, Regina DND\MIS wrote:
> Hi Abe,
> The people I work with are very interested in this project since part of the
> selling of this to the rest of the departments is getting it to work with
> ArcGIS.  I started trying to compile your project, but unfortunately ran
> into problems with trying to get the ArcGIS objects dependency dlls.
> I'm not new to .NET, but haven't done anything with ArcObjects and I was
> trying to find the dlls on the ArcMap 9.1 cd we have but couldn't find it
> there.  Hopefully we can be of some help if not at least trying to test it
> with ArcGIS 9.1.
> Someone here said there is an extra kit we may need to get the ESRI
> dependency files which we may not have, but they weren't sure.  So where do
> we get the ESRI dependency files or does that require an extra developer
> purchase from ESRI?
> Thanks,
> Regina
