[postgis-users] problem installing postgis with geos support
Jonathan Aguero
jua130 at psu.edu
Thu Oct 6 10:44:51 PDT 2005
Davis and all,
No, I din't do a make disclean before running the make and make install
again. I am quite new in linux and I didn't know how to "reinstall" software
though I was suspecting something like that may be the cause of my problem.
So to be more specific on my problem:
OS=FC4
Geos 2.1.4
PostGIS 1.0.4
Pgsql 8.0.4
I first installed PostGIS without geos support and then I modified the
Make.config file to include geos support and ran again the make-make install
secuence without knowing that I need it to run a make disclean. So do you
think a make disclean is what I need? How do I run it?
Thanks
Jonathan Aguero Valverde, MS
Graduate Student
Civil and Environmental Engineering
The Pennsylvania State University
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of david
techer
Sent: Thursday, October 06, 2005 1:57 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] problem installing postgis with geos support
Did U do a make disclean before make again
or can you more informations about what U did:
- commands, systems, version and so on...???
--david;
Jean David TECHER
e-mail: davidtecher(at)yahoo(dot)fr
site: http://techer.pascal.free.fr/postgis/
Jonathan Aguero a écrit :
>Dear All,
>I haven't being able to install postgis with geos support.
>I checked in the list posts and I tried some suggestions like installing
>geos then using ldconfig and finally compiling postgis again but no
>luck.
>I modified the Make.config to enable geos support but when I finally
>created a new database the function postgis_version() returns a geos =
>0.
>The function postgis_geos_version() returns an empty row which I guess
>means that geos support for postgis is not properly installed.
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez cette version sur http://fr.messenger.yahoo.com
