[postgis-users] I need to simplify a table
José Vicente Higón Valero
higon_jos at gva.es
Fri Oct 7 00:18:26 PDT 2005
Hi list,
I'm a beginner in postgis and I want to simplify a table in order to
serve a layer with full extent in mapserver.
I have done these steps with a table of multipoligons:
First, I reduce the table with Simplify function:
create table muni_simplify as (select gid,Simplify(the_geom,100) as
the_geom,provincias from muni_pol_10k)
Second, I group the records:
create table muni_collect as (select Collect(the_geom) as the_geom from
muni_simplify group by provincias)
Later, I try to export the created table to a shapefile but the
geometrycollection isn't support by pgsql2shp, how can I collect into
multipoligon? I can't use the function addGeometryType in the created
table 'muni_collect', why?. Is my approach correct?
Thaks in advance.
José Vicente Higón
Grupo de desarrollo de gvSIG
Conselleria de Infraestructuras y Transporte
Generalitat Valenciana
Valencia - Spain
tlf. 963862397
http://www.gvsig.gva.es
