[postgis-users] problem installing postgis with geos support
david techer
davidtecher at yahoo.fr
Thu Oct 6 13:50:10 PDT 2005
Welcome in PostGIS World ;-)
--david;
Jean David TECHER
e-mail: davidtecher(at)yahoo(dot)fr
site: http://techer.pascal.free.fr/postgis/
Jonathan Aguero a écrit :
>David,
>It works perfectly, now postgis is running with geos support.
>Thank you very much!
>Jonathan
>On Fri, 2005-10-07 at 00:11 +0400, david techer wrote:
>>Hum...!
>>First have U installed geos?..................I think it is OK
>>SO let try a command in order to see if geos is installed
>>geos-config --version
>>which should send U something like
>>2.1.4
>>In Makefile.config when U replace
>>USE_GEOS=0
>>by
>>USE_GEOS=1
>>be carefull that there is no space after 1, it seems perhaps here it is your error:
>>Good: 'USE_GEOS=1'
>>Bad: 'USE_GEOS=1 '
>>then do
>>make distclean
>>make
>>make install
>>then do
>>cat /etc/ld.so.conf
>>in order to be sure that the path /usr/local/lib is in this file. If not:
>>echo /usr/local/lib >> /etc/ld.so.conf
>>then run in order to be able to use the new *.so for your fedora:
>>ldconfig
>>regards.
>>--david;
>>Jean David TECHER
>>>Davis and all,
>>>No, I din't do a make disclean before running the make and make install
>>>again. I am quite new in linux and I didn't know how to "reinstall" software
>>>though I was suspecting something like that may be the cause of my problem.
>>>So to be more specific on my problem:
>>>OS=FC4
>>>Geos 2.1.4
>>>PostGIS 1.0.4
>>>Pgsql 8.0.4
>>>I first installed PostGIS without geos support and then I modified the
>>>Make.config file to include geos support and ran again the make-make install
>>>secuence without knowing that I need it to run a make disclean. So do you
>>>think a make disclean is what I need? How do I run it?
>>>Thanks
>>>Jonathan Aguero Valverde, MS
>>>Graduate Student
>>>Civil and Environmental Engineering
>>>The Pennsylvania State University
>>>-----Original Message-----
>>>From: postgis-users-bounces at postgis.refractions.net
>>>[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of david
>>>techer
>>>Sent: Thursday, October 06, 2005 1:57 AM
>>>To: PostGIS Users Discussion
>>>Subject: Re: [postgis-users] problem installing postgis with geos support
>>>Did U do a make disclean before make again
>>>or can you more informations about what U did:
>>>- commands, systems, version and so on...???
>>>--david;
>>>Jean David TECHER
>>>>Dear All,
>>>>I haven't being able to install postgis with geos support.
>>>>I checked in the list posts and I tried some suggestions like installing
>>>>geos then using ldconfig and finally compiling postgis again but no
>>>>luck.
>>>>I modified the Make.config to enable geos support but when I finally
>>>>created a new database the function postgis_version() returns a geos =
>>>>0.
>>>>The function postgis_geos_version() returns an empty row which I guess
>>>>means that geos support for postgis is not properly installed.
>>>>_______________________________________________
>>>>postgis-users mailing list
>>>>postgis-users at postgis.refractions.net
>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>___________________________________________________________________________
>>>Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
>>>Téléchargez cette version sur http://fr.messenger.yahoo.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051007/21fda041/attachment.html>
