[postgis-users] data in mapserver
Frances Collier
fcollier at preparedresponse.com
Wed Oct 12 15:31:26 PDT 2005
I'm not sure if this is the correct listing to post to, but I thought I'd
give it a try. I am trying to load a layer from postgis into mapserver. I
believe I finally got the connection working correctly, but when I run the
.map through mapserver the layer does not show up. I then tried to run the
.map file through shp2img and the layer did not show up. I have no idea what
I'm doing wrong and am sure it has to do more with my lack of experience
with mapserver than postgis. Below is the layer code from my .map file.
LAYER
NAME "principal"
GROUP "roads"
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=dcmms user=postgres password=w0rk1n
host=map.rapidresponder.com port=5432"
DATA "wkb_geometry from wacounties"
STATUS on
TYPE line
LABELCACHE on
LABELITEM "county_nm"
CLASSITEM "ecy_region"
MAXSCALE 4000000
MINSCALE 80001
CLASS
NAME "Principal Hwy"
EXPRESSION /Principal Highway*/
STYLE
SYMBOL "BigLine"
SIZE 3
COLOR 171 158 137
END
OVERLAYSYMBOL "DashedLine"
OVERLAYSIZE 1
OVERLAYCOLOR 255 255 255
# TEXT ([FEATURE],[NAME])
LABEL
TYPE truetype
FONT "arial"
MINFEATURESIZE 50
MINDISTANCE 100
ANGLE auto
COLOR 0 0 0
SIZE 8
END
END
END
Any help or direction is greatly appreciated.
-Frances
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051012/df87e9ec/attachment.html>
