[postgis-users] data in mapserver
Ethan Alpert
ealpert at digitalglobe.com
Wed Oct 12 15:40:03 PDT 2005
The top 4 reasons a layer doesn't show up are:
You don't have STATUS set to DEFAULT or if you have STATUS set to ON you
are not providing layers= in the your URL
You have the wrong projection
You have the wrong extents
You are rendering at a scale that is not within your MINSCALE/MAXSCALE
-e
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Frances Collier
Sent: Wednesday, October 12, 2005 4:31 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] data in mapserver
I'm not sure if this is the correct listing to post to, but I
thought I'd give it a try. I am trying to load a layer from postgis into
mapserver. I believe I finally got the connection working correctly, but
when I run the .map through mapserver the layer does not show up. I then
tried to run the .map file through shp2img and the layer did not show
up. I have no idea what I'm doing wrong and am sure it has to do more
with my lack of experience with mapserver than postgis. Below is the
layer code from my .map file.
LAYER
NAME "principal"
GROUP "roads"
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=dcmms user=postgres password=w0rk1n
host=map.rapidresponder.com port=5432"
DATA "wkb_geometry from wacounties"
STATUS on
TYPE line
LABELCACHE on
LABELITEM "county_nm"
CLASSITEM "ecy_region"
MAXSCALE 4000000
MINSCALE 80001
CLASS
NAME "Principal Hwy"
EXPRESSION /Principal Highway*/
STYLE
SYMBOL "BigLine"
SIZE 3
COLOR 171 158 137
END
OVERLAYSYMBOL "DashedLine"
OVERLAYSIZE 1
OVERLAYCOLOR 255 255 255
# TEXT ([FEATURE],[NAME])
LABEL
TYPE truetype
FONT "arial"
MINFEATURESIZE 50
MINDISTANCE 100
ANGLE auto
COLOR 0 0 0
SIZE 8
END
END
END
Any help or direction is greatly appreciated.
-Frances
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051012/93c8c6aa/attachment.html>
