[postgis-users] Re: libpostgis library
Markus Schaber
schabi at logix-tt.com
Mon Oct 17 01:55:28 PDT 2005
Hi, Frances,
Frances Collier wrote:
> I have the liblwgeom.dll, however, it is not in the Win32 directory (it
> is in the PostgreSQL\8.0\lib directory). Do I need to put it there for
> PostGIS to return the data to mapserver properly?
No, this is the correct directory for PostgreSQL extensions like PostGIS.
> After running “SELECT postgis_full_version()” I got:
> POSTGIS=”1.0.1” GEOS=”2.1.4” PROJ=”Rel. 4.4.9, 29 Oct 2004” USE_STATS
> DBPROC=”0.3.0” RELPROC=”0.3.0”
This output tells us that your PostgreSQL has successfully found the
liblwgeom.dll, and works with it.
Thus, the problem has to be somewhere else, maybe your MapServer query
definition.
Does Mapserver return any error messages? What SRID is your data in, and
what does Mapserver expect?
Maybe the Mapserver experts here or on the Mapserver list can give you
more help.
Markus
