[postgis-users] postgis installation problem
Paul Scott
pscott at uwc.ac.za
Tue Oct 18 09:11:06 PDT 2005
createlang plpgsql yourdb should fix it.
--Paul
>>> rschumeyer at ieee.org 10/18/05 5:55 PM >>>
I'm trying to install postgis 1.0.4 with postgresql 8.0.4.
In addition, I have installed proj 4.4.9 and geos 2.1.4.
If I leave the postgis Makefile.config alone everything works fine.
However, if I edit Makefile.config to say:
USE_PROJ ?= 1
USE_GEOS ?= 1
then I get shared library errors when I attempt to run
$psql -f lwpostgis.sql -d yourdatabase
BEGIN
psql:lwpostgis.sql:35: NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
psql:lwpostgis.sql:35: ERROR: could not load library
"/usr/local/pgsql/lib/liblwgeom.so.1.0": libgeos.so.2: cannot open
shared
object file: No such file or directory
The shared library does in fact exist in that location.
Any help is appreciated!
