[postgis-users] postgis installation problem
strk at refractions.net
Tue Oct 18 09:16:31 PDT 2005
On Tue, Oct 18, 2005 at 11:55:13AM -0400, Rick Schumeyer wrote:
> psql:lwpostgis.sql:35: ERROR: could not load library
> "/usr/local/pgsql/lib/liblwgeom.so.1.0": libgeos.so.2: cannot open shared
> object file: No such file or directory
> The shared library does in fact exist in that location.
Under a GNU system (Linux is one of them) you must run
the ldconfig(8) command after library install.
It's a very common question, maybe we should update the FAQ, or
the wiki. Volunteers ?
--strk;
