[postgis-users] Restore woes Postgres 8.0.3 / Postgis 0.9.1 to Postgres 8.1 b3 / Postgis 1.0.4 on Windows
Johan Wehtje
genwolf at gmail.com
Fri Oct 21 23:26:33 PDT 2005
Thanks your reply,
I will give that a try.
Cheers
Johan Wehtje
On 10/22/05, Steffen Macke <sdteffen at gmail.com> wrote:
> Johan,
> > Any suggestions as to how to upgrade without data loss?
> Use the PERL script postgis_restore.pl (You should find it in
> the share/contrib/postgis folder).
> The PostGIS manual contains instructions how to use the file (It
> requires the dump file to be in a special format).
> As you seem to be running on Windows, you should install e.g.
> ActivePerl in order to be able to run PERL scripts.
> Regards,
> Steffen
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051022/4e27aae8/attachment.html>
