[postgis-users] Restore woes Postgres 8.0.3 / Postgis 0.9.1 to Postgres 8.1 b3 / Postgis 1.0.4 on Windows
Steffen Macke sdteffen at gmail.com
Fri Oct 21 23:23:17 PDT 2005
Johan,
>  Any suggestions as to how to upgrade without data loss?
Use the PERL script postgis_restore.pl (You should find it in
the share/contrib/postgis folder).
The PostGIS manual contains instructions how to use the file (It
requires the dump file to be in a special format).
As you seem to be running on Windows, you should install e.g.
ActivePerl in order to be able to run PERL scripts.
Regards,
Steffen
