[postgis-users] help command pgsql2shp
Maher_Karim at dorsch.com.jo Maher_Karim at dorsch.com.jo
Tue Oct 25 09:26:03 PDT 2005
You can use the command line like follows:
pgsql2shp -u postgres -g the_geom -P password -f test testgis "select *
from LT where name = XXX"
where
u: user name
P:password
g: geometry column field name.
f: shapefile name
Regards
Maher
zourite at cegetel.net
Sent by: postgis-users-bounces at postgis.refractions.net
10/25/2005 05:28 PM
Please respond to PostGIS Users Discussion
        To:     postgis-users at postgis.refractions.net
        cc:
        Subject:        [postgis-users] help command pgsql2shp
Hello
Is anyone can give me an example of pgsql2shp command with sql query in
option. Is there a documentation of this function (may be i could write
it).
I'm looking for something like this :
pgsql2shp -f c:\test.shp testgis 'select * from LT where name = XXX' but
it doesn't work !
Thanks
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051025/c4f4aeb4/attachment.html>
