Slow postGIS data query (was RE: [postgis-users] mapserver dbconnection)
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Oct 26 02:16:52 PDT 2005
> -----Original Message-----
> From:	postgis-users-bounces at postgis.refractions.net on behalf
> of Frances
> Collier
> Sent:	Mon 10/24/2005 1:29 PM
> To:	postgis-users at postgis.refractions.net
> Cc:
> Subject:	[postgis-users] mapserver db connection
> Hello,
> I've been trying to find out what exactly Mapserver gets back
> from Postgis when querying the tables. I haven't found this
> to be documented anywhere. Does Postgis return a shape file,
> layer, or simply data rows? The reason I'm asking is that I
> noticed a huge time difference between connecting to Postgis
> and simply calling the shape files - with the Postgis being
> significantly slower. I know Postgis offers a lot more
> functionality, but for simple comparisons I do not have any
> type of filter applied.
> I'd appreciate any knowledge, advice, and/or direction.
> Thank you,
> Frances Collier
Hi Frances,
What do you mean by significantly slower? Can you quantify this in seconds,
for example a shapefile query is instant whereas a PostGIS query takes 5s?
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
