[postgis-users] Postgres 8.1beta2 crash with 3D (and beyond) geometries..
Alex Mayrhofer axelm-postgis at nona.net
Sun Oct 30 11:16:16 PST 2005
I'm trying to use geometries with dimensions > 2 on one of my test machines.
   Table creation was fine (i was using a 4D POINT geometry), however, when
PostGIS tries to parse a POINT geometry with dimension > 2 (tried with
3d/4d, just POINTs), Postgres crashes:
first is fine, second makes postgis crash:
geotest=# select geomfromtext('POINT( 0 0)');
                 geomfromtext
  000000000100000000000000000000000000000000
(1 row)
geotest=# select geomfromtext('POINT( 0 0 0)');
WARNING:  OGC WKT expected, EWKT provided - use GeomFromEWKT() for this
CONTEXT:  SQL function "geomfromtext" statement 1
server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
!> \q
This can be reproduced at any time.
I'm running the following configuration:
geotest=# select postgis_full_Version();
                                          postgis_full_version
  POSTGIS="1.0.4" GEOS="2.1.3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.0" RELPROC="0.3.0"
(1 row)
geotest=# select version();
                                               version
  PostgreSQL 8.1beta2 on sparc-unknown-linux-gnu, compiled by GCC cc (GCC)
3.3.5 (Debian 1:3.3.5-13)
(1 row)
Everything seems to run fine for 2D geometries - this was my first attempt
at 3d geometries on this box.
The system is an UltraSparc machine, Postgres as well as PostGIS are running
in 32bit userland. A gdb backtrace of a crashed postmaster shows a SIGBUS,
and a corrupted stack.
Can i track this down somehow in a "standalone mode" of PostGIS only? I'd
rather not like to recompile Postgres to include debugging stuff..
I'd appreciate any comments on how to proceed here - still hoping i've
triggered a well-known bug...
thanks
Alex Mayrhofer
