[postgis-users] problem for converting shp to sql on postgis
Gregory S. Williamson
gsw at globexplorer.com
Thu Sep 1 13:16:50 PDT 2005
I am guessing this is a postGIS 1.x variant, so to see the geometry with the SRID use asEWKT(transform(SetSRID(the_geom,4266), ... )
The asEWKT gets you the SRID representation; asWKT gets the geometry text without the SRID.
Greg
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Meng - Luen Tseng
Sent: Thu 9/1/2005 12:24 PM
To: postgis-users at postgis.refractions.net
Cc:
Subject: [postgis-users] problem for converting shp to sql on postgis
I have one problem. when i using shp2pgsql to convert shp file into sql
file and run the sql file to insert data into database. The data format is
like this:
sdb=# select
st_nm_pref,st_nm_base,st_typ_aft,st_nm_suff,r_refaddr,r_nrefaddr,l_
refaddr,l_nrefaddr,r_postcode,l_postcode,transform(SetSRID(the_geom,4269),26941)
,distance(transform(SetSRID(the_geom,4269),26941),
transform(GeometryFromText( '
POINT(-121.9722 37.30554)', 4269),26941) ),
transform(GeometryFromText('POINT(-1
21.9722 37.30554)',4269),26941) from roads where the_geom &&
'BOX3D(-121.9822 37
.29554, -121.9622 37.31554)'::box3d order by distance limit 1;
st_nm_pref | st_nm_base | st_typ_aft | st_nm_suff | r_refaddr | r_nrefaddr |
l_
refaddr | l_nrefaddr | r_postcode | l_postcode |
transform
| distance | transform
| ROEWILL | DR | | 1198 | 1000
| 11
99 | 1001 | 95117 | 95117 |
01050000203D6900000100000001020
000000500000059C2D9EF2C8E3E41E9758813C8C21041E85877F1248E3E41DB90DCF5D0C21041B7B
A2047228E3E411C01644CDEC21041924E6963218E3E41BD13F615F0C210413CF15C851F8E3E41969
166E36FC71041 | 4.10093259484239 |
01010000203D690000BD359CE9248E3E41249A41DC53C
41041
(1 row)
The data desplay like Hex on column 'transform'
The correct should be:
sdb=# select
'BOX3D(-121.9822 37
l_
transform
| 11
SRID=26941;MULTILINESTRING((200
2476.93691649 274610.019075242,2002468.94322735
274612.240099204,2002466.2778431
6 274615.574600235,2002465.38832561 274620.021446521,2002463.52094944
274907.972
070955)) | 4.10093259485145 | SRID=26941;POINT(2002468.91253982
274708.965094002
Could some body help me how to solve this problem?
Thank you very much.
Allen
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today - it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
!DSPAM:43175592158511417013841!
