[postgis-users] [BUGFIX] GiST leaks (Out Of Memory Error)
strk at refractions.net
Fri Sep 2 23:19:24 PDT 2005
After an hard battle against PostgreSQL memory manager
hiding leaks I hopefully fixed the OOM users are
reporting on big tables indexing.
As soon as affected users will confirm the fix version
1.0.4 will be out, with these changes:
- Memory leak plugged in GiST indexing
- Segfault fix in transform() handling of proj4 errors
- Fixed some proj4 texts in spatial_ref_sys (missing +proj)
- GiST indexing cleanup
- Loader: fixed string functions usage, reworked NULL objects check,
fixed segfault on MULTILINESTRING input.
- Fixed bug in MakeLine dimension handling
--strk;
