[postgis-users] [BUGFIX] GiST leaks (Out Of Memory Error)
joe at omc-international.com.au joe at omc-international.com.au
Sat Sep 3 03:49:55 PDT 2005
> After an hard battle against PostgreSQL memory manager
> hiding leaks I hopefully fixed the OOM users are
> reporting on big tables indexing.
> As soon as affected users will confirm the fix version
> 1.0.4 will be out, with these changes:
What is the best way to do this?
should we download from cvs and try it?
>         - Memory leak plugged in GiST indexing
>         - Segfault fix in transform() handling of proj4 errors
>         - Fixed some proj4 texts in spatial_ref_sys (missing +proj)
>         - GiST indexing cleanup
>         - Loader: fixed string functions usage, reworked NULL objects
> check,
>           fixed segfault on MULTILINESTRING input.
>         - Fixed bug in MakeLine dimension handling
> --strk;
> postgis-users mailing list
