[postgis-users] Tiger Geocoder from Refractions
Mark Leslie
mark at refractions.net
Wed Sep 7 10:25:17 PDT 2005
Jamie,
There was a bit of normalization put into the data for the geocoder.
Looking through the
script, the tables we seem to need are roads_local, tiger_geocode_roads
and tiger_geocode_join. roads_local
is basically the results of ogr2ogr. We did some processing to extract
county and zipcode boundaries
and such. tiger_geocode_roads is a subset of roads_local. It looks
like: (id integer, fedirp char(2), fename char(30),
fetype char(4), fedirs char(2), zip char(6), state varchar(64), county
varchar(64), cousub varchar(64), place varchar(64), geom geometry).
tiger_geocode_join links the two. I've been looking for the scripts I
used to generate the but I think they were a
casualty of a recent disk space shortage, but this should give you
something to work with.
Mark
Jamie Taylor wrote:
>Hi -
>I've be trying to get the Tiger Geocoder that is
>downloadable from the Refractions web site working.
>I have loaded the Tiger Line data (for other reasons)
>into a PostGIS enabled database, using ogr2ogr...but
>the references in the two SQL files don't look
>anything like the relations I have from my Tiger load
>(e.g., tiger_geocode_roads.*)
>I'm guessing there is some normalization step that is
>assumed to have taken place, or some other loading
>process that people have used.
>Thoughts? Help/Suggestions? Has anyone made this work?
>Thanks!
>J
>__________________________________________________
>Do You Yahoo!?
>Tired of spam? Yahoo! Mail has the best spam protection around
>http://mail.yahoo.com
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
