[postgis-users] Why does this take almost 3 hours?
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Fri Sep 9 00:31:37 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Ethan Alpert
> Sent: 08 September 2005 23:03
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Why does this take almost 3 hours?
> Although when I first posted I hadn't run
> update_geometry_stats() (I'm using 7.4.6) I do have that in a
> nightly cron job.
> I just reran my query with the same time results so it
> appears to have had no affect.
> -e
Hi Ethan,
And can you confirm the version of PostGIS you are using (the output from
SELECT postgis_version()?). Both of these are really important when trying
to work out why bad query plans have been chosen.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
