[postgis-users] 1.0.4 Released
Paul Ramsey
pramsey at refractions.net
Fri Sep 9 09:29:28 PDT 2005
PostGIS'ers,
1.0.4 is at the hotdog stand. The small memory leak that affected
large table indexing is gone. Change log is:
- Memory leak plugged in GiST indexing
- Segfault fix in transform() handling of proj4 errors
- Fixed some proj4 texts in spatial_ref_sys (missing +proj)
- GiST indexing cleanup
- Loader: fixed string functions usage, reworked NULL
objects check,
fixed segfault on MULTILINESTRING input.
- Fixed bug in MakeLine dimension handling
- Looser syntax acceptance in box3d parser
- Documentation improvements
- More robust selectivity estimator
- Minor speedup in distance()
- Minor cleanups
- Fixed bug in translate() corrupting output bounding box
