[postgis-users] 1.0.4 Released
Don Drake
don at drakeconsult.com
Sat Sep 10 15:58:20 PDT 2005
Is a full dump/restore required for this upgrade?
-Don
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, September 09, 2005 11:29 AM
To: PostGIS Users Discussion
Subject: [postgis-users] 1.0.4 Released
PostGIS'ers,
1.0.4 is at the hotdog stand. The small memory leak that affected
large table indexing is gone. Change log is:
- Memory leak plugged in GiST indexing
- Segfault fix in transform() handling of proj4 errors
- Fixed some proj4 texts in spatial_ref_sys (missing +proj)
- GiST indexing cleanup
- Loader: fixed string functions usage, reworked NULL
objects check,
fixed segfault on MULTILINESTRING input.
- Fixed bug in MakeLine dimension handling
- Looser syntax acceptance in box3d parser
- Documentation improvements
- More robust selectivity estimator
- Minor speedup in distance()
- Minor cleanups
- Fixed bug in translate() corrupting output bounding box
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
