[postgis-users] 1.0.4 Released
Paul Ramsey
pramsey at refractions.net
Sat Sep 10 19:37:24 PDT 2005
Nope. Compile and install.
On 10-Sep-05, at 3:58 PM, Don Drake wrote:
> Is a full dump/restore required for this upgrade?
> -Don
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Paul
> Ramsey
> Sent: Friday, September 09, 2005 11:29 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] 1.0.4 Released
> PostGIS'ers,
> 1.0.4 is at the hotdog stand. The small memory leak that affected
> large table indexing is gone. Change log is:
> - Memory leak plugged in GiST indexing
> - Segfault fix in transform() handling of proj4 errors
> - Fixed some proj4 texts in spatial_ref_sys (missing +proj)
> - GiST indexing cleanup
> - Loader: fixed string functions usage, reworked NULL
> objects check,
> fixed segfault on MULTILINESTRING input.
> - Fixed bug in MakeLine dimension handling
> - Looser syntax acceptance in box3d parser
> - Documentation improvements
> - More robust selectivity estimator
> - Minor speedup in distance()
> - Minor cleanups
> - Fixed bug in translate() corrupting output bounding box
> postgis-users mailing list
