[postgis-users] Windows installer and 8.1-dev1
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Tue Sep 13 07:01:23 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of christian.graefe at web.de
> Sent: 13 September 2005 14:46
> To: PostGISUsersDiscussion
> Subject: [postgis-users] Windows installer and 8.1-dev1
> Hello @all
> I tried successfully to install the 8.1-dev1 windows binary,
> which was releases last week.
> Afterwards i tried the latest postgis installer but it failed
> while loading lwpostgis.sql. I got the following message:
> ERROR: could not load library
> "C:/Programme/PostgreSQL/8.1-dev1/lib/liblwgeom.dll":
> Die angegebene Prozedur wurde nicht gefunden.
> TRANSLATION: The procedure was not found.
> Any ideas was went wrong?
Hi Chrischan,
Do you mean the latest PostGIS installer from
http://www.webbased.co.uk/mca/? If so, these are only for PostgreSQL 8.0
since as you mention above, the PostgreSQL 8.1 installer will already have
PostGIS 1.0.x series included.
Since the 8.1 and 8.0 versions are compiled differently, you will need to
reinstall PostGIS from the 8.1 beta 1 installer for things to start working
again.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
