[postgis-users] Windows installer and 8.1-dev1
christian.graefe at web.de
Tue Sep 13 07:23:08 PDT 2005
PostGIS Users Discussion <postgis-users at postgis.refractions.net> schrieb am 13.09.05 16:01:51:
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of christian.graefe at web.de
> > Sent: 13 September 2005 14:46
> > To: PostGISUsersDiscussion
> > Subject: [postgis-users] Windows installer and 8.1-dev1
> > Hello @all
> > I tried successfully to install the 8.1-dev1 windows binary,
> > which was releases last week.
> > Afterwards i tried the latest postgis installer but it failed
> > while loading lwpostgis.sql. I got the following message:
> > ERROR: could not load library
> > "C:/Programme/PostgreSQL/8.1-dev1/lib/liblwgeom.dll":
> > Die angegebene Prozedur wurde nicht gefunden.
> > TRANSLATION: The procedure was not found.
> > Any ideas was went wrong?
> Hi Chrischan,
> Do you mean the latest PostGIS installer from
> http://www.webbased.co.uk/mca/? If so, these are only for PostgreSQL 8.0
> since as you mention above, the PostgreSQL 8.1 installer will already have
> PostGIS 1.0.x series included.
> Since the 8.1 and 8.0 versions are compiled differently, you will need to
> reinstall PostGIS from the 8.1 beta 1 installer for things to start working
> again.
Thanks for your clarification!
Is there already a timeline when the installer for 8.1 will be
released?
Greetings Chrischan
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-users mailing list
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050913/f0ad7045/attachment.bin>
