[postgis-users] importing shape files nightmare!
strk at refractions.net
Wed Sep 14 23:13:58 PDT 2005
Version 1.0.4 of PostGIS contains a fix for your case.
--strk;
On Wed, Sep 14, 2005 at 11:38:54PM +0200, christomec wrote:
> I have two machines, suse and gentoo
> suse:
> select version();
> PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.3.5
> 20050117 (prerelease) (SUSE Linux)
> select postgis_full_version();
> POSTGIS="1.0.3" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS DBPROC="0.3.0"
> RELPROC="0.3.0"
> gentoo:
> select version();
> i686-pc-linux-gnu-gcc (GCC) 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0, pie-8.7.8)
> POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.3.1" RELPROC="0.3.1"
> running:
> shp2pgsql -c streets.shp streets | psql -d dbname
> suse, no problem!
> gentoo: ERROR: unterminated quoted string at or near
> "'010500000001000000010...
> trying:
> shp2pgsql -D streets.shp streets dbname > streets.sql
> suse, no problem!
> gentoo:
> Shapefile type: Arc
> Postgis type: MULTILINESTRING[2]
> Segmentation fault
> finally:
> Trying to import streets.sql generated on the suse machine into postgresql
> running on the gentoo machine also fails:
> psql:streets.sql:1350: invalid command \N
> What is it with the gentoo installation? What should I upgrade or
> downgrade to remedy this problems I'm having?
> Please help, it is really important that I get this done and I'm really
> stuck trying to solve it.
> Kind Regards,
> Christo Du Preez
> postgis-users mailing list
