[postgis-users] importing shape files nightmare!
christomec
christo at mecola.com
Wed Sep 14 14:38:54 PDT 2005
I have two machines, suse and gentoo
suse:
select version();
PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.3.5
20050117 (prerelease) (SUSE Linux)
select postgis_full_version();
POSTGIS="1.0.3" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS DBPROC="0.3.0"
RELPROC="0.3.0"
gentoo:
select version();
i686-pc-linux-gnu-gcc (GCC) 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0, pie-8.7.8)
POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.1" RELPROC="0.3.1"
running:
shp2pgsql -c streets.shp streets | psql -d dbname
suse, no problem!
gentoo: ERROR: unterminated quoted string at or near
"'010500000001000000010...
trying:
shp2pgsql -D streets.shp streets dbname > streets.sql
suse, no problem!
gentoo:
Shapefile type: Arc
Postgis type: MULTILINESTRING[2]
Segmentation fault
finally:
Trying to import streets.sql generated on the suse machine into postgresql
running on the gentoo machine also fails:
psql:streets.sql:1350: invalid command \N
What is it with the gentoo installation? What should I upgrade or
downgrade to remedy this problems I'm having?
Please help, it is really important that I get this done and I'm really
stuck trying to solve it.
Kind Regards,
Christo Du Preez
